Assembly weight status
I cannot get the OK weight status for my assembly
Weight calculation report for work part says - The following parts did not have their expected reference set
How to avoid this?
6 REPLIES 6
Re: Assembly weight status
Hi @alex_c,
May be one or more components are having 'empty' reference set. Try changing components' reference set to 'model' or 'entire part'.
Hope it helps.
Amol
In sub-assembly there is a promote body
I think this can be a reason(?)
@alex_c , you can try deleting and calculating the weight again to figure out if Promote Body is the culprit.
I see a IR having the same issue which was resolved when sub-assemblies are added to new part file. Also when make sub-assembly displayed part, it was showing the correct weight data.
Samadhan
GTAC | NX Help: NX1102 | NX1202 | NX1847
Please mark post as an "Accepted Solution", if it answers your question/is more helpful!
The weight data (Mass) is correct in most cases, but i'm confused by component weight status - why it's become unreliable
Can you share the solution for this IR?
@alex_c , it's closed as Technical question (TQ) and the answer I've already posted in previous post.
Samadhan
