Assign NX10 material library xml into NX11
when I assign NX10 material library xml into NX11 an information error appear :
Information listing created by Me
Date 25-Aug-2016 16:39:00
Current work part C:\Drawing Files\model1.prt
Node name XXXX
Unable to map property (Mass Density (RHO)_6) to a property in the NX Model.
Unable to map property (Youngs Modulus (E)_31) to a property in the NX Model.
Unable to map property (Yield Strength_32) to a property in the NX Model.
Unable to map property (Ultimate Tensile Strength_33) to a property in the NX Model.
Unable to map property (Fatigue Strength Coefficient_20) to a property in the NX Model.
Unable to map property (Strength Coefficient_21) to a property in the NX Model.
Unable to map property (Thermal Expansion (A)_34) to a property in the NX Model.
Unable to map property (Thermal Conductivity (K)_35) to a property in the NX Model.
Unable to map property (CSYSOption) to a property in the NX Model.
How can I resolve ?
Thank you...
Using NX11 and NX1847
RuleDesigner PDM
Re: Assign NX10 material library xml into NX11
Better messaging was put in NX11 for reporting unsupported properties. The diagnostic messages should have been improved to identify the material(s) where properties and/or units cannot be mapped to NX.
For example, the listing above mentions "Youngs Modulus (E)_31" - for which the "_31" is likely not being recognized by NX. NX understands various names as Young's Modulus ( "YoungsModulus" "Youngs Modulus" "Young's Modulus" "Young'sModulus" "Youngs Modulus (E)" "Young's Modulus (E)" "ModulusofElasticity" "Modulus of Elasticity" "Modulus of Elasticity (E) "Modulus, L" "E").
The CSYSOption property is not supported in the material data model.
If you're unable to identify the problematic materials in the XML file that have the unsupported properties I would suggest logging a call with GTAC for assistance.
Regards, Ben
