Associative Copy
How to use associative copy in Nx10.
In nx 8.5 there was option called insatnt geometry in that we are able to copy the parent  component in to number of components after that change in parent gonna reflect on copied component.
how can we achive that in Nx10?
Re: Associative Copy
Siemens Legend Siemens Legend
Siemens Legend
Chait22,
Are you looking to copy a component in an assembly, if yes then use pattern component in NX 10. If you want just geometry then you can use Pattern Geometry, if you want features then use Pattern Features and if you want to copy faces then use Pattern Face.
Paul
