Associative Weight for Sheet Bodies
I need to get the weight of an assembly that contains some (many) components modeled with Sheet Bodies (no solids).
first question: is it possible to get an associative value for the weight (Mass) of a Sheet Body? The command Mass using Curves and Sheets only gives an explicit value, it seems.
And if the answer is yes, how do I link this value to the MassPropMass attribute so that it can automatically be read in the Advanced Weight Management?
Thankyou!
