Attributes in Electrode design
Builder
Builder
After create blank in Electrode Design, NX insert attribute "MW_STOCK_SIZE". Is possible create this attribute with 1 decimal places (for example 15x15x52)?
Re: Attributes in Electrode design
Look for the Stock Size dialog, I think it's the same as Mold Wizard, you should be able to set it there.
You can edit the value.. Erase the .000 (15.000 becomes 15)
Sen
Builder
Builder
Yes, both soultions are possible, but i wanted automatic solution. This attribute created automatic, after create electrode.
