Auto Update Sheet in Drafting
Quick simple question. Is there an option I can turn on or off that will allow my sheets in drafting to automatically update with I make changes to my parts?
Thanks you.
Re: Auto Update Sheet in Drafting
Yes.  It's a NX Customer Default setting.  In NX 10, it's within the "Drafting Standard" section.  Preference is called "Deplay View Update".
Larry Carpenter, P.E.
That worked well. Now my question is why do I still have the red X's in the up to date column on my draft. The changes were applied but it says its now up to date.
Thank you for your response.
