Autoballon autoorder in NX
Hi everyone!
I have problem with autoballon in draft. There is any posibiity to make automatic order with ballons, because I have so many parts  and it is  big mess on th draft after I add autoballons  and it take to many time to make it maually. Someone is able to help me?
Best regards
Re: Autoballon autoorder in NX
Automatic order with ballons?
Could you please explain more with some example. It will be easy to help you.
Still need details...
