Autoballoons on different sheets
Hello everyone.
I'm new here and it's my first topic.
Is there any way to create autoballoons on different sheets using only one parts list on the first sheet?
Re: Autoballoons on different sheets
Add a balloon without any text on the second sheet. Tag the leader to your item.
RMB and select auto balloon.
I've tried to do it but it works only when I add the main assembly on second/third/etc sheets. But when I create base view of the subassembly or of the detail on the other sheets then the autoballoons don't generate...
Your work flow is a bit different then what I do.
Hopefully another user will have an answer.
Look at the NX help for environment varaiable:
   UGII_UPDATE_ALL_ID_SYMBOLS_WITH_PLIST
"But when I create base view of the subassembly or of the detail on the other sheets then the autoballoons don't generate..."
If you add a view from another model file, you will end up with a "drafting component" type of view. These won't show up in a parts list and I don't think you can add balloons to them either...
https://docs.plm.automation.siemens.com/tdoc/nx/12/nx_help#uid:xid1128417:index_drafting:id701237:ba...
Thank you for your answers.
I have another question regarding the auto balloons- is there any possibility to set creating auto balloons on face? By default, nx creates auto balloons on the edge...
