Automatic centerlines off when creating views in drawing ?
Hello
How to set automatic centerlines off by default when creating new views in drawing ?
- Views now look like pierced with thousands of needles and it is slow.
6 REPLIES 6
Re: Automatic centerlines off when creating views in drawing ?
Menu > Preferences > Drafting
In the Drafting preferences dialog go to:
View > Common > General
And uncheck "Create with centerlines".
Any other ways to make large&heavy views more lighter for computer ?
- Mine "large views" are so slow it takes 15min to make a view of the assembly :-(
- Updating drawing views takes >15min sometimes 30min.
Do you already use smartlight weight views?
Also you can play with the hidden lines preferences for small objects.
this option will hide small feature lines.
this can help with some preformance.
Ruud van den Brand
Pre-sales NX CAD
cards PLM Solutions
Hello
I just can't find the "centerlines OFF" option ?
- Where is it in Customer Defaults I'm using NX 9.0 ?
Is it this that says just "Centerlines" ?
  • I have again large assemblies with a lot of centerlines...
Yes that's the setting.
Check also you drafting preferences in your drafting template.
Tip: if you hold your mouse on the question mark it gives a popup with the information about the setting.
Ruud van den Brand
Pre-sales NX CAD
cards PLM Solutions
