Automation of parametric model
Hello
I am planning to develop a parametric wing model using NX. The idea is to use programming to achieve automatic creation & update of the model geometry and mesh pattern (pre-processing of FE), which is expected to facilitate my structural optimisation work.
I am wondering are there any specific tools/options available in NX which can achieve this objective? Or what are the common methods that NX users usually apply for this kind of task?
Many thanks
Chao
Re: Automation of parametric model
Siemens Legend Siemens Legend
Siemens Legend
I have seen a demo of such a "piece", I think it was built using Knowledge Fusion , which is a "programming language" in NX.
You can probably use any programming language which "hooks into NX".
The case i saw was to optimize the cold shape of jet engine turbine blades such that the hot, working shape, should be optimal.
Tomas
