Autoorder of dimensions
Hello  everyone!
How I can make autodimenssions and  autoorder of dimensions in NX in draft?
best regards
Lukipap
Re: Autoorder of dimensions
you can take some help from FEATURE PARAMETERS for autodimension (not all features but still ...)
For auto order (distributing it properly) use DISTRIBUTE ANNOTATIONS.
Kapil
the command 'DISTRIBUTE ANNOTATIONS' is found but not available ?
I've lost some news ?
Thank you...
Using NX1859
RuleDesigner PDM
 I can access it and use it also in NX11.0.2.
Best Regards
Kapil
Hi @kapilsharma,
if you see the command and me not, then this command is under special license like Drawing Automation.
Thank you...
Using NX1859
RuleDesigner PDM
Smiley Happy yes i guess that is correct (lmtools also directs in that direction) ...
Probably a drafting expert can throw some more light on it.
Best Regards
Kapil
Hi @cubalibre00,
You need a license increment called "nx_drawing_auto". From what I'm reading it looks like this is available in the following three bundles:
NX30130 - Drafting Plus
NX30173 - Drawing Automation for NX
NX10105 - NX Mach Power Drafting
Regards, Ben
