Balloon in drawing of parts from assembly
Hello.
I have an assembly. Then I create drawing for that assembly with part list and auto ballon.
Then I create next sheet and I this sheet I make drawing from one part of the assembly. In this drawing I create ballon and here is my problem. What I need to do to get a number this part from part list in this ballon automaticly (associatively) ?
3 REPLIES 3
Re: Balloon in drawing of parts from assembly
Honored Contributor
Honored Contributor
Did you run update, on the parts list?  that should do it.
-Dave
"and I this sheet I make drawing from one part of the assembly"
How did you create a drawing of this one part? If you added a view from the component part file, this will result in a "drafting component" that will not be recognized by the parts list. In other words, you will not be able to add an automatic balloon to this drawing view if it is a drafting component.
Hello.
Thanks for answers. I send video to show how i did it.
If is any other possible solution I will be grateful to get how to do it.
