Base view far away from border even in 1/10 scale ?
Hello
- Lots of mouse dragging to get it inside the NX borders.
- What can I do to ? Change part's origo ? How to do it and how does it effect assembly ?
5 REPLIES 5
Re: Base view far away from border even in 1/10 scale ?
can you share this part?
Ruud van den Brand
Pre-sales NX CAD
cards PLM Solutions
you can always change the boudary to the size that you want.
Right click view border->boundary->set this to manual rectangle. Drag a manual border around the objects that you want.
this will resize the border. and maybe will take less draging of your views.
Ruud van den Brand
Pre-sales NX CAD
cards PLM Solutions
Some assemblies behave this way.
The border is very long when placed to the drafting (Place base view).
normally the border is as big as the geometry thats inside of it.
Ruud van den Brand
Pre-sales NX CAD
cards PLM Solutions
Occasionally there is a piece of geometry "lost in space" - you might want to try part cleanup, or something else to try to identify if there is something in an unexpected location.
