Base view in drafting
Hello guys,
in my company we use now NX9 going from NX75. The problem that I submit is the following:
when you insert a view in NX75, the view is taken, by default, by the drafting file part (see image), while the opposite occurs with NX9 (see image).
Is there a way to set the customer default so that NX9 acts like NX75?
Re: Base view in drafting
Yes it can be set to use as before (NX7.5).
Contact your supplier or GTAC to get the variable required.
