Base view
In a drawing I have created a base view and then a proyected view. Afterwards I have deleted the base view and I would like to convert the proyected view to base view.
Re: Base view
Why? What difference does it make in your application?
Re: Base view
When exporting dxf I would like to choose base view scale
Re: Base view
can't you use the sheet scale?
Check this under Edit sheet feature.
Ruud van den Brand
Pre-sales NX CAD
cards PLM Solutions
Re: Base view
When I export to dxf I only can choose "user defined" "base view" and "no scale". I am translating the meaning, I dont know how NX shows it in english.
Re: Base view
Is there no way of set a proyected view as base view?
Re: Base view
No, it's not possible. You'll have to determine the scale of the projected view prior to the translation, if that's the scale you want to use. Similarly a part can have multiple base views with different scales - NX will only list the scale of the initially placed base view, so again, you'd have to determine the scales of the remaining base views if you wanted to translate at a different scale. Consider opening an IR with GTAC if you want to submit an enhancement request to convert an orthographic view to a base view, or to allow scales from other views on the drawing to be made available on the DXF/DWG Wizard.
Regards, Ben
