Basic nonlinear solution (SOL106) for calculating the problem with load variants
I am using femap/nxnastran with basic nonlinear FEA (SOL106). I want to calculate the structural response at the below loads. can I do it? or must I use advanced nonlinear solution (SOL106)?
0. 0.
1. 1.
2. 0.
Re: Basic nonlinear solution (SOL106) for calculating the problem with load variants
Hello @ljc,
I would suggest you ask your question in the Simcenter 3D - Femap part of the community. You're more likely to get answers on this there.
https://community.plm.automation.siemens.com/t5/3D-Simulation-Femap-Forum/bd-p/Simcenter_3DFemap_for...
Kind regards,
Dennis
Dennis de Brouwer
Application Support Engineer
GTAC EMEA - Siemens Industry Software
