Basic sketch
Can someone tell me how to make reference line on edge of sloped surface of cup in sketch? I know convert but how to lean it on?
Thank you.
Re: Basic sketch
Ciao @IloveAudi86,
I'm not sure that I completely understand your question, in NX yuo can use, in Sketch Environment, all parametric tools such as Intersection Curve and then convert to reference.
Ciao
Re: Basic sketch
If you are trying to Constrain to a curve outwith the current Sketch, remember to set your selection Filter to Within Work Part.
Re: Basic sketch
Use Intersection curve, select the entire face and project it on a plane, then you will be able to use the sloped curve as a reference for your sketch.
