Best process for saving multiple files
Happy Monday!
I'm looking for a good process to saving multiple parts or an assembly file to a different location. I have investigated the NX Help Documentation but I have only found Save, Save As..., Save All, Save as Bookmark, and Save Options. None of these options are what we're looking for. We are trying to save the assembly into a new direction, either local or server folder.
We don't have a TCE license. The only other option is to save each active part separately.
Does anybody have a good process or macro to save all part files under an assembly?
Jason
Re: Best process for saving multiple files
"Clone assembly" can be used to create a copy of the assembly and its components to a different location.
https://docs.plm.automation.siemens.com/tdoc/nx/10/nx_help/#uid:index_assemblies:func_details_clone_...
Also, there is a 3rd party utility called "UGZip" that will create a zip file of your assembly and components. Perhaps this utility could be helpful for your task. Search the forum for "UGZip", you should find several threads about it.
