Blank Nesting
Hi every body,
How to adjust raw material size  as Boundary for blank nesting feature?
thanks
DW89mk
Re: Blank Nesting
Hello @dw89mk,
Can you provide a little more detail so we can help in the best way possible?
Is you design in sheet metal or a different application?
Are you looking for a visual indicator (curve) or some finite limit?
thanks
Dave
Re: Blank Nesting
Hi Dave,
Thanks for your quick response
How to define boundary size (length and width in the specific value) in the blank nesting feature so that we can define an optimal number of part and we can maximize the material utilization?
of course this is related to sheet metal part
I tried it in the NX12 but it look like not flexible, we cannot define length and width in the specific value
can we do it in the NX blank nesting feature?
Please advice
Thank you
dadang
Re: Blank Nesting
Hello @dw89mk,
OK, so you are in the Progressive Die application.  I must refer this to someone more experienced in that area.
