Bookmarks settings?
Does anyone know where the bookmark file or settings are stored? I am using them for assemblies, and they do not appear to be retained in the part file.
Glenn Balon
Production: NX 12.0.2 MP10 Primarily CAM
Re: Bookmarks settings?
Check if there is path defined under the customer defaults settings for the Bookmark Directory.
Normally when you save the bookmark, it prompts for the file name to save.
Thanks, I will update and use my own location. Still not sure where they end up by default though.
Glenn Balon
