Break-out section removes cross hatch
If I add a break-out section view to an existing assembly sectioned view, some of the cross hatched components loose there cross hacthing. Has anyone else seen this?
Victor Cohen Engineering manager American Tool & Mold NX11.0.2.7 MP5 Windows10 Nvidia Quadro P5000
4 REPLIES 4
Re: Break-out section removes cross hatch
Hi Vcohen,
Can you please share few images about the issue if possible?
Amol
@vcohen,
It seems to me that the issue is you're creating a break out section in a section view and NX isn't sectioning the upper/left component once you add the break out section.
If possible, I would add a step in the section line if I wanted to see crosshatching.
Tim
NX 11.0.2.7 MP11 Rev. A
GM TcE v11.2.3.1
GM GPDL v11-A.3.7
Hi @vcohen,
I tried to reproduce the issue you are facing but failed. Could you please try changing section setting from "format" & "crosshatch"?
View > Setting > Section
Hope it helps.
Amol
