Broken-out sections
Builder
Builder
Last week I created a broken-out section on a drawing. Today the part has been revised and the broken-out section is no longer showing the correct depth. I've gone into view-dependant edit but I can't seem to just remove the old broken-out section?
Is there a way to just remove a broken-out section or do I have to create a new view? (I hope not.)
Thanks in advance.
Re: Broken-out sections
The command is used to Create, Edit and Delete the Break out section.
Ciao
In NX10 on the Break-Out Section dialog is a Delete option
John Joyce, Manufacturing Engineer,
Senior Aerospace
NX 11.0.2.7 Vericut 8.0.3 - Statements and opinions are mine alone and do not reflect
the opinion of my employer or any other member of the human race
Are you just trying to repair the section view? Or remove it all together?
Here's a link to a procedure in the Help collection that demonstrates how to edit a Break-out section view:
Here's a link that shows how to delete a Break-out section view.
Do eifther of these procedures help you solve your problem?
 (Fixed links, sorry about that)
@MKarsten: You need to start the 'Break-out Section View' command and use Edit, Delete options. Attached a video in which using Edit option base point is changed to redefine the depth of break out in Isometric view .
@DEckhoff: Links are not opening, so I am posting them from NX10 documentation.
Edit a break-out section view
Delete a break-out section view
Ganesh Kadole
