Cadenas in Reuse Library
Hi all,
read this one:
https://community.plm.automation.siemens.com/t5/NX-Design-Knowledge-Base/Import-Catchbook-DXF-amp-CA...
So, how do I add Cadenas to Reuse Library?
ER
32 REPLIES 32
Re: Cadenas in Reuse Library
@dziubelis wrote:
Hi all,
read this one:
ER
Cadenas  reuse library will be implemented in the future NX11 or in NX12.
Thank you...
Using NX1859
RuleDesigner PDM
Is it available in current NX11?
No. From NX Release Notes :
Data Reuse
Caveats
CADENAS Library in the Reuse Library The CADENAS Library is not yet available. It will be provided in a later release.
Thank you...
Using NX1859
RuleDesigner PDM
Siemens Legend Siemens Legend
Siemens Legend
From what I understood Cadenas in RL will be available in NX11.0.1.
I have a customer that is currently using cadena, integrated in NX and is working very well using Cadenas interface.
The problem I see with this integration between the 2 products is about the management of my actual Part Families (with all the "intelligence": Attributes, KRX, Remember Constraint, etc) that, for sure, will be duplicated in the Cadenas DB.
Beppe G
Siemens PLM Italy
Will this be availabe for all designer bundles/licences/mach solutions?
This information it is helpful for me too.
Kind regards,
Beppino
Come on, its a simple question.
Siemens Legend
A few things here.
Firstly the availablity, we are currently working on this and the holdup is not technical but paperwork based, so this will likely be NX 11.0.2 or NX 12.
In terms of the question is it available for Mach and the old bundles yes as it works with the reuse library.
Is there any news about that, now that 11.0.1 has been released?
