Can't copy+paste Tabular note(=Revision change table) to new drawing ?
Hello
What might be the cause ?:
In drawing I can't copy+paste Tabular note(=Revision change table) to a new drawing ?
  • The drawing is inside a model (no separate drawing file).
  • When pasteing nothing comes up...
  • I can copy+paste on my own assemblies succesfully but not inside this someone else's made file assembly and parts.
AND
  • How to make a stretched boundary box small again ? (Stretched due to/because of updating the model. I tried but "Anchor Point" tab is now always visible... How to remove it ?)
Re: Can't copy+paste Tabular note(=Revision change table) to new drawing ?
When you paste the tabular note does your work layer count increase (meaning that something pasted but you can't see it). If it does increase, check to see if your current work layer is invisible on the drawing sheet using "Layer Visible in View".
Regarding the view boundary - right click on the boundary and see if it is set to Manual Boundary. If it is, change it to Automatic and see if that cleans things up. I'm not sure why you're seeing anchor point if you have the dialog closed. Perhaps try a view refresh (F5) or View Regenerate?
Regards, Ben
