Cannot success to export from drafting to dxf on NX11
Hi!
I want to export from drafing to dxf on NX11.
But, I cannot success to export from drafting to dxf...
There are any issue about setting or something to export from drafting to dxf on NX11?
Please let me know~!!!
Thank you!
4 REPLIES 4
Re: Cannot success to export from drafting to dxf on NX11
Can you give some more information.
What is not exact possible? don't you get a dxf file or the things in the DXF not correct?
Maybe add some screenshots or a movie of the steps that you do.
Ruud van den Brand
Pre-sales NX CAD
cards PLM Solutions
Do you have a license for the DXF export/translator?
(I'm assuming it is a separate license, not included with Gateway or whatever)
Hi!
I tried to export > AutoCAD DXF/DWG Export on NX11 Drafting Mode like as below.
But, be exported center lines only.
I tried several times, but I can earn same results.
Additionally, my NX bundle is NX10101.
hank you!
And I tried traditional cheat.
Translate CGM first, and then translate DXF.
But, also I earned same result...
