Chamfer Dimension in section view
I’m trying to put a chamfer dimension in a section view of a cylinder, but NX seems not to select the reference object.
How to procedure?
chamfrer.PNGNXchamfer2.PNGSolidworks
Re: Chamfer Dimension in section view
Section or not, NX Chamfer dimension supports only 45°.
The way I'm taking it "That NX prompts you chamfers that are not 45° by not supporting them with Chamfer Dimension"  Man LOL
Michael Fernando
Die Designer
NX 11.0.2.7 + PDW
Hi @Zoppellari,
@mike_fdo is correct.
Documentation: Chamfer Dimension
"For any chamfer that varies from 45 degrees, you must use other dimensioning techniques to dimension it."
Regards, Ben
