Change curve color in NX drafting
Hi all,
I want to change curve color in NX drafting. Now, I have to convert to DXF file and use Autocad to change the color of curves. Anyone know how to do this in NX drafting?
Thank you so much.
Unable to play video. Please try again later.
(view in My Videos)
Re: Change curve color in NX drafting
You can set monochrome setting on or off in the drawing.
This will changes you display from black and white to color views.
https://docs.plm.automation.siemens.com/tdoc/nx/12.0.1/nx_help/#uidSmiley Tonguereferences_pref_create_mono
Ruud van den Brand
Pre-sales NX CAD
cards PLM Solutions
Thank you so much @
