Change displayed part option
NX9
I swear there is a setting, when you have a component that is the display part, and you change to display the assembly.  I have one user where is changes the assembly to the work part, not allowing a work in context, unless the user makes the component the work part again.
First suspicion was a metric component in inch assembly, but that is not the case.
Where is this setting?  I'm obviously not using the right search word in the Customer Defaults.
-Dave
Re: Change displayed part option
Found it...the key is to post the question here, then you will find the solution.
-Dave
The customer defaults has a 'tooltip' that says it only affects the default value, the real value is stored in the registry. If changing the customer default doesn't work for you, try going to preferences -> assemblies -> work part: maintain.
Dealing with large assemblies, it takes considerbale time to display parent assembly part and then making it as work part. This preference is really helpful. Smiley Happy
Ganesh
