Change new templates for old drawings
We have legacy drawings with title blocks containing old fields and company logo.  We want to replace with new template definitions(Title block, borders, logo) for these drawings without touching the drawing views, annotations..  Does NX support template change for existing drawings? If so, how do we do it?
3 REPLIES 3
Re: Change new templates for old drawings
As far as I know, you can't change from old to new.  The old formats used wire framed font and templates, the new formats use a different technology.  If you could find a way, you would have issues because the Text is totally different. Trutype Font and wireframe font is so much different. Good or BAD, we maintain both. Dan
Hi smartsubbu,
there is no Siemens-provided way to replace the old title block with a new one. Most companies to it manually when they have to update an old drawing.
you can read this topic https://community.plm.automation.siemens.com/t5/NX-Design-Forum/Switch-drawing-template/td-p/465935.
Thank you...
Using NX1867
RuleDesigner PDM
