Change the dimensionality of an expression?
Builder
Builder
Is it possible to change the dimensionality of an expression? For example, in the figure below how would you change the expression N from a Length type to Constant?  Thanks.
EDIT: I figured it out.  The reason I couldn't edit the dimensionality was because the expression (N) was being referenced by another part via an Interpart Expression. Once I removed that, I could edit it (as shown below).  Now, if I could only figure these things out before posting! Smiley Happy  But hopefully this will help someone else at some point.
4 REPLIES 4
Re: Change the dimensionality of an expression?
Great job there pmk3!
As long as the expression is not in use you are free to change the type.
TIP - mark your post as Accepted Solution and other will know that there is a solution ;-)
Best Regards
Fred
Builder
Builder
Actually I can't. It doesn't give me the option.  Apparently I can only mark an actual reply as an accepted solution. I guess that's one drawback to editing my post rather than replying to it.
pmk3
So post the solution to your question as a reply and then Accept it as a Solution ;-)
Best Regards
Fred
Builder
Builder
Good idea Fred!
