Changing View display for PMI
I am trying to set PMI on a part in 3D. A linear size tolerance seems to only display perpendicular to a cylinder or perpendicular to a view. Even if I change the orientation plane, ZC-YC or other, it seems to change or shift but never really set the size tolerance to the correct parallel view or in line with the cylinder.
Is there an easier way to change the view of linear tolerances or their view?
Re: Changing View display for PMI
You can change the plane orientation to "User defined".
Just orient the CSYS for the desired orientation plane and click Ok.
See picture below for the reference.
Hope I could help you.
Sen
