Changing decimal places in drafting
I know I saw a response earlier to this question, but can't find it.
NX8.5 you could double click a dim and change from 2 to 3 to 4 decimal places by just hitting the # desired from keyboard.
NX11 lost that function.
Siemen's didn't know of that option, John Baker option- I think it was called, but came up with a temp solution to bring it back.
Can anyone tell me that solution, again??
Thanks.
Re: Changing decimal places in drafting
Hold down the "Alt" key and then select the number.
Regards, Ben
Thanks.
But it doesn't work using Feature Parameter dimensions.
Confirmed. But it does work with the new Radial Dimension command if you use the new Hole Callout method. Call GTAC if you want to pursue having the Feature Parameter callout corrected.
