Changing the drawing sheet mode and std symbols
Hello all,
Two questions I wanted to ask
1. Is there a way to change the drawing sheet mode from landscape to portrait..or vice versa!
2. How to set up standard symbols for drafting and custom symbols as well and everytime I wanted to open it has to be there !
Re: Changing the drawing sheet mode and std symbols
1) Go to Edit sheet-->custom size-->change the values of height & lenght.
2) Just Drag & drop the required command/option and Place it on Top border Bar or where ever you want.
Have you set your sheet sizes i Customer Defaults?
Have you set a path to your Symbol library?
Sure.. I'll do that .
Thanks @joewhite Smiley Happy
Hello...
Thanks for your suggestion but there is no direct option like landscape or portrait?
You have to type all the Landscape and Portrait sizes into the Customer Defaults so they appear on your Edit Sheet dropdown.
