Checkmate
Honored Contributor
Honored Contributor
Just starting to look into Checkmate, and wondering if anyone has found some good "how to" resources?
We use Teamcenter, so if there are any tricks working in there, that would be appreciated too.
-Dave
-Dave
Re: Checkmate
Community Manager
Hi @DaveK,
@SamKuan created a series of videos on how to use Check-Mate in NX. You can find them in our Knowldedge Base area:
Prismatic Mill
Sheet Metal
Assembly
Hopefully those videos help you.
Best,
Amy Allen
Product Engineering Software
Siemens PLM Software, Inc.
Community Manager, Solid Edge
Become a Solid Edge Certified pro today!
Re: Checkmate
DFMPRO is an add on from Siemens through a company called Geometric.
We use this DFMPRO it is a nice set of checks.  It has some issues and many false positives.  You have to pay attention how you have the rule file setup.
Also you can export your results to teamcenter and set up valadation work flows with these results.  This can be done with any checkmate result.
Writing Checkmate checks you will have to have the Checkmate author license.
I hope this helps a little bit.
