Clocking Angle on Wire Harness Drawing
I'm new to NX Electrical Routing (and wire harness in general), so maybe there's an obvious answer I'm missing.
I want to call out the clocking angle of connectors on drawings, but it seems when I create a formboard in NX, all connectors have their rotation vector oriented the same direction. Is there any way to avoid this in NX, or is there some best practice for values to use when rotating components on the formboard?
