Color isn't same in exporting PDF and Drafting
Hi everyone,
I have a problem when I export a drawing to PDF, color in the PDF file seems darker  than one in Drawing. Anyone here knows why? and How I fix it?
Re: Color isn't same in exporting PDF and Drafting
I actually have the same issue but with NX11.
Never figure a way around it.
Hello i had the same issue, but you can fix it. following this workaround:
1. open Drawing
2. change to application Modeling
3. Menu, View, Visualization, Basic Lights
4. "Reset to Default Lights" set "Scene Left Top" and "Scene Right Top" to value 0.9
5. return to Drafting and File, Export, PDF
6. The Colored PDF is nearly the same as in NX
hope this helps
