Color representation from 3D to 2D
Im trying to change the lines in certain areas to a specific color to show the change in the drawing, and i cannot find good material to do so.
3 REPLIES 3
Re: Color representation from 3D to 2D
Hi @Mcopeland ,
Please attach an image explaining what you want. That will help us give you correct/suitable solution.
Samadhan
GTAC | NX Help: NX1102 | NX1202 | NX1847
Please mark post as an "Accepted Solution", if it answers your question/is more helpful!
Hi @Mcopeland
Although not very clear what you need but if you want to see some edges with color in your drawing:
1- extract that edge using "Composite Curve" command.
2- change the color of that curve using "Edit Object Display"
3- create your drawing and uncheck Monochrome Display in "Visualization Preferences" to make your drawing show the colors
I hope it helps.
Awesome, thank you. I needed this infor for a CAD test in a week, i have only dealt with black and white so colors didnt matter on the drawing. Your answer helped a lot.
