Colour of a electrical routing connection
Hello everyone!
How can I see in a model the colour assigned to the connection in the electrical routing?
Re: Colour of a electrical routing connection
Have you tried "information -> object..."?
Perhaps I wasn't specific. I mean - is it possible to have solids representing wired stock to be visibly assigned specific colours?
Hi Scaffold,
Yes you can assign the color to the specific stock.I hope this is what you asked for?route1.jpg
Best Regards
Kapil
Then if I route other wires they assume the colour of the wire that was routed first, and not the one from the stock setting. Try routing others with the different colours and check if it works for you.
Hi Scaffold,
The wires will have the same color as specified (left to right : Green...cyan...grey and yellow).
The bundle diameter color however will be set by the routing preferences.(shown as dark blue )
Best Regards
Kapil
What am I doing wrong then?
This video is currently being processed. Please try again in a few minutes.
(view in My Videos)
Update. I'm afraid there is a problem with my video. It is not uploaded properly.
I tried this in NX11 and it worked fine. What is your version?
Version should not be an issue (the image is from NX11 but i have been on it since NX6/7/8.)
Best Regards
Kapil
I have the problem on NX10. It paints pin-level wires the same colour. The same file in NX11 does not have that problem. I contacted GTAC over this issue.
