Command Favorite Data
I had created favorite data for many commands. I can start the command use the favorite defined. Now I want to check for which commands favorite data is saved. Is there any way to check them altogether, where can I find it?
Ganesh
Re: Command Favorite Data
You can find your favorites under your home directory in Windows.
<YOUR HOME DIR>\AppData\Local\Siemens\NX110\Favorites\
The favorites are stored as .fav files. You can view the content of the file to see which feature it relates to.
@DickBaardse; Yes, Now I can know the all favorite data defined. Thanks for the answer! Smiley Happy
Ganesh
