Common License File
trying open the zip file to load the NX student edition
everything goes perfect till i need to load the license.
receive a message as follows.
UGS Common License File
The specified license file can only be used with a license server installation.
Install the ugs_licensing product.
thank you
5 REPLIES 5
Re: Common License File
What does start your license file look like? Attached are images from two example license files. The one on the left uses a host ID (as I think student editions use). The one on the right has a composite ID. Does your license have a COMPOSITE= as highlighted in the one on the right? Or does it look like the one on the left?
Anthony Galante
Senior Support Engineer
PhoenxPLM
Thank You for responding .
To be honest my license looks completely different from your examples.
have included a copy for you all to view.
Thank you look forward to your help and completing the home work at home.
K. Keller
The license file you posted has expired.  You'll have to request a new one.
Thank You for your time.
would you be kind enough to point in the right direction for he new license.
Thank You
K.Keller
I sent you a PM.
