Component Instance Name, Code Adjustment
Re: Component Instance Name, Code Adjustment
This type of question is better suited to the Programming and customization forum.
If you are getting 12233445/A but only want 12233445, you can use C#'s string functions to search in the string for the forward slash and extract only the text up to the forward slash character.
