Constrain
How to constrain two different  sketches are in different plane .
Constrain - Point on curve , tangent
6 REPLIES 6
Re: Constrain
Hi @S7 .
Within active sketch, invoke geometric constraint and set the selection filter to 'Within Work Part Only' and select the required sketch objects/curves/points to create the constraint.
Re: Constrain
i am not getting solution in this file
Spoiler
Re: Constrain
Ciao @S7 ,
maybe there is also a timestamp problem, you can not constrain a sketch that was created first to a sketch that was created later.
Ciao
Re: Constrain
What can we do? Any solutions
Re: Constrain
Hi @S7 ,
Please find video below which uses Composite Curve and Move Object command:
(view in My Videos)
Samadhan
GTAC | NX Help: NX1102 | NX1202 | NX1847
Please mark post as an "Accepted Solution", if it answers your question/is more helpful!
Re: Constrain
Hi @S7
Sometimes direct constraining to other sketches is not possible because of the plane angles. In such cases you should use somethings like "Intersection Point", "Project Curve",...
(view in My Videos)
