Constraint axis
Hey,
I was wondering if you know a constraint of something of that kind which defines that an axis can only rotate around his own axis in an assembly. He shouldn't be moved or rotated around any other axis.
Thank you in advance,
NielsVP
Re: Constraint axis
Could you please share some use case with us?
Kapil
Re: Constraint axis
I would like to keep this axis in this position. His only degree of freedom should be around his Z-axis
Re: Constraint axis
Ok...you can constrain the axis (TOUCH/ALIGN-Infer axis ) with a datum axis (Z) of the parent part (assembly part).
Kapil
Re: Constraint axis
Yeah but if I do that, I can still move the entire assembly along every other axis
Re: Constraint axis
The "INFER AXIS" option restricts it to revolve around the one axis
Re: Constraint axis
In my opinion you will first need a component (the first one may be you will add to your assembly) that will be fixed (permanently may be) and then you can use "Infer Axis" constraint to constrain the axis of your component with the first one.
Kapil
