Converting XYZ co-ordinate data to points in NX11
Hi all,
I have some co-ordinate data of points on a face of a scanned circular profile, which I would like to visualise in NX. Essentially, this data is point cloud data but in Excel format.
I would like to input these points to create the profile in a digital environment. Does anyone know if a tool to do this lies within NX's many functions? Hand-entry is fine but if there's a way to input an Excel table or similar that would be even better.
Many thanks,
Alex
Re: Converting XYZ co-ordinate data to points in NX11
NX has an import points from file function. I don't think it will use Excel files directly, but you should be able to export your points to a usable text file format fairly easily.
Thank you, this is perfect.
Exporting to .txt worked just fine
