Convex Edge Blend Only (Filter or Function Selection)
Does anyone know if there is a filter to only select edges for an edge blend that would form only convex blends?
I have a very large and elaborate panel and I need to figure out a way to only select convex corners between surfaces to reduce the time its going to take doing this by indivdual clicks.
Thanks!
Re: Convex Edge Blend Only (Filter or Function Selection)
Use the 'Rib Top Face Edges' selection intent. It will only select edges which define convex blends. Of course, this will blend all the edges associated with the selected face wich fit the criteria.
The way to use it would be to select one face at a time and hit apply in between.
This probably won't satisfy all your requirements but I hope this helps somewhat.
Abe
Abe
That definitely does help. As you said not perfect, but speeds along the blend creation process at least a little.
Thanks!
