Core cavity
Can anyone help me to make core cavity for this non planer profile part.i here attached the .step file of the part
Re: Core cavity
This depends on your intent.  If you simply need the internal volume and external volume you can create a copy of the body and then use delete face on each to achieve your goal.  See attached part.
If you need the part split you could still use the result to get what you're looking for.
Re: Core cavity
Thanks for your reply..i can't open the file can u give a .step file ..if u don't mind kindly share the video file..this is my mail id vaithisnc@gmail.com
Re: Core cavity
Here is the video and a .step file for you.  Let me know if this is what you needed.
Unable to play video. Please try again later.
(view in My Videos)
Re: Core cavity
Re: Core cavity
(view in My Videos)
