Corners in Routing Mechanical
Hi, I've been using NX since some months. I can't apply miter on corners with three lines connected, another thing is extend the stock or profile to end of other stock, however, I need that stock 1 overlap stock 2. Somebody know how to do these?
Re: Corners in Routing Mechanical
Can you please provide some pictures of your requirement? I think i got your point to some extent but just want to be sure.
Best Regards
Kapil
Hi Kapil, off course!
Follow images that explain somethings that I need to do.
On picture Frame1 you can view the first moment, add stock.
On picture Frame_Solution1 has a miter treatment between stocks 1 and 2, while stock 3 go to there.
On Picture Frame_Solution2 has a cope treatment between stocks 2 and 3, while stock 1 go to there without ajust your orientation about line, I just can do this when stock 1 is inside of the line in NX.
sorry for a late reply....i could not think of any way of achieving the same (3 point corner) in routing as of now. Mitre works for 2 point corner only so synchronous is the only way i can rely on.
Kapil
