Re: Create a CAM
Hi @Cesare,
walls of thicken feature are radial to the cylindrical surface, but in the real world are parallel to the axis tool. The demostration is that the distance from a wall and the opposite respect to the up and botton are different.
Thank you...
Using NX1859
RuleDesigner PDM
Re: Create a CAM
Part attached.
//Fred
Re: Create a CAM
hi @Sandman,
I will try the solution with multi swept volume.
Thank you...
Using NX1859
RuleDesigner PDM
Re: Create a CAM
4 tool runs (Swep Volume) using a consistens tool size diameter of 12 will do the trick.
//Fred
