Create a Library for Chain
How to creat or reuse Chanin from NX? Please help me !
3 REPLIES 3
Re: Create a Library for Chain
We do not understand your question.  Could you be more specific?
Are you trying to use the chaining selection method?
Or, are you trying to create a model of a steel chain?
Dear,
I want to create a library for Chain the same Gear Library .
You need to use 'Menu -> Tools -> Reuse Library-> Reuse Library Management.'
When the reuse library management dialog opens, press F1 to open the Help Documentation for the reuse library.
If you have difficulty, I highly recommend you check with GTAC in your local area for additional assistance.
