Create own checker at Check-Mate
We are using UDF as much as possible to create threaded holes. If engineer can't use the UDF, he will add a threaded hole without UDF. I am looking for a check-mate that is marking the holes they are not created with a UDF. Is this possible?
Re: Create own checker at Check-Mate
We don't have an out-of-the-box checker for this specific question, but it would certainly be possible to create one.
If you're proficient in NX Open and are interested in writing this yourself, there are a bunch of examples that you could use to get started with this.
If you're interested in having someone else write this check for you, then you may want to contact your sales rep and ask for a quote.  (...and if they don't have any idea what you're talking about, feel freet o send them to me.)  :-)
Does that help?
Taylor Anderson
NX Product Manager, Knowledge Reuse and NX Design
Tel: +1 (602) 441-0683
taylor.anderson@siemens.com
Taylor,
Thanks for your answer. We will search for this
Thijs Janssen
